Horn Relay
Old Jun 27, 2008 | 03:57 PM
wormshoe's Avatar
wormshoe
Horn Relay
My truck is a 1989 F150 5.0 2WD 5 spd. Does anyone know where the horn relay is located ? Thanks.
Old Jun 27, 2008 | 05:41 PM
Franklin2's Avatar
Franklin2
Up through at least the 86 model, if you do not have cruise, you do not have a horn relay. Dont know about the 89 model. If you have cruise, then the horn relay is located under the dash on the driver's side above the kick panel area.
Old Jun 27, 2008 | 09:16 PM
wormshoe's Avatar
wormshoe
Thanks for the advice.
I had been trying to find it under the hood and drew a blank. (My '89 does have cruise control.) I will look under the dash tomorrow.
My horn works just fine when the ignition key is in the off position, but it does not work when it is in the run position. I thought changing out the horn relay (it's the original) might make a difference. Have you ever seen this problem before ?
Thanks again. worm
Old Jun 27, 2008 | 09:51 PM
fmc400's Avatar
fmc400
MSEE
If you still can't find it, try disconnecting the horn under the hood, then press the horn pad to make the relay click. Follow the sound to find the relay. Always works for me.
Old Jun 27, 2008 | 09:55 PM
wormshoe's Avatar
wormshoe
Originally Posted by fmc400
..... try disconnecting the horn under the hood, then press the horn pad to make the relay click. Follow the sound to find the relay.
That's one helluva an idea. I like that. Thank you sir.....
worm
Old Jun 28, 2008 | 11:55 AM
Franklin2's Avatar
Franklin2
I have seen your problem before, and it's usually a grounding issue in the column. If you want to try an experiment, take the horn pad off so you can get to the end of the steering shaft. Then try the horn, and see if it still works with the key off, and not with the key on. Then take a scrap piece of wire and bolt one end to a good body ground, and touch the other end to the metal steering shaft where the steering wheel bolts on. Then turn the key on and see if it works. If it does, then you do have a grounding problem. What you might want to try is go out under the hood, and make a short jumper wire to go from one side of the rag joint at the steering column shaft, over to the other side of the rag joint on the steering box side. This will ground the steering shaft through the steering box.
Old Jun 28, 2008 | 05:35 PM
wormshoe's Avatar
wormshoe
You guys are sharp !!!! My bones hurt too much today to try anything. I will give it a whirl on Sunday if I catch some slack from my back...
Thanks again.
Worm
Old Jun 30, 2008 | 03:32 PM
wormshoe's Avatar
wormshoe
fmc400,
I did what you suggtested and it has led me to an area on the passenger's side directly behind the glove box. I have asked one of my local parts guys to confirm the location....and he did. Do I have to drop the dash to get at it ? ( '89 F150 5.0 A/C cruise 5 spd 2 WD )
I appreciate your advice.
To summarize: the horn relay responds (clicks) in the accessory position and the off position, but does not respond in the run position. Your idea is actually pretty cool, but it still puzzles me that the horn will work in these positions, but not when the vehicle is actually running.
Your thoughts please.....
Thank you for your time.
worm
Old Jun 30, 2008 | 04:33 PM
fmc400's Avatar
fmc400
MSEE
If the relay is clicking in at least those key positions, then you know the relay is good. I don't think you need to spend your time pulling the relay. Only one wire leaves the switched side of the relay coil - the same wire is used to actuate the relay regardless of where the key is at. Something in the steering column is keeping that wire from grounding when the key is on. I think your problem lies in the key switch or the steering column. I would try Franklin2's suggestions.
Old Jun 30, 2008 | 08:40 PM
wormshoe's Avatar
wormshoe
Frankin2,
FMC400 agrees with you and I will be trying to make sure that the shaft is grounded as per your suggestion. I really appreciate you guys taking a second look at this problem. I have really been up against it. I don't use my horn that much, but it sure is nice to blast someone every once-in-a-while !
I will take a jumper cable and go from the shaft (above the U-joint) to the negative terminal of the battery....the best ground on the vehicle. I will let you know what happens. Thank you very much !!
worm
Old Jul 3, 2008 | 09:23 AM
wormshoe's Avatar
wormshoe
Originally Posted by wormshoe
Frankin2,
worm
No change at all.....
worm
Old Jul 3, 2008 | 04:33 PM
Franklin2's Avatar
Franklin2
Find the horn button wire itself, and ground it to see what happens. It should be the one that is attached to the slide ring behind the steering wheel.
centralNH
May 20, 2014 07:00 PM
Free Man 1949
1997 - 2003 F150
Apr 12, 2013 05:44 AM
93aero257k
Aerostar
Apr 18, 2005 09:30 AM
vanmannj
Electrical Systems/Wiring
Dec 31, 2004 06:48 PM
country boy
Nov 8, 2002 04:30 PM
