vaccum hose replacement
Old Jun 27, 2008 | 03:43 PM
MYTRUCK's Avatar
MYTRUCK
i need to replace the metel pipe to the 2 speed shifter on the rear end- from the fronton my 1948 f6. the old pipe was badley rusted.the only pipes that i have found is two thick.doe anyone know iwhat i can use rubber hose or somthing else. thank for the help
Old Jun 27, 2008 | 03:56 PM
mechmagcn's Avatar
mechmagcn
What size is the steel tubing? I would either use copper tubing or plastic air brake tubing to replace it.
Old Jun 27, 2008 | 07:58 PM
MYTRUCK's Avatar
MYTRUCK
the id in 1/2-
