Sponsored by: Auxito
99 Ford F150-Need Help!
Old Jun 26, 2008 | 03:33 PM
skcurtdrof's Avatar
skcurtdrof
Exclamation 99 Ford F150-Need Help!
Hey Everyone!
I could use some help I am getting a little frustrated with my truck. It is a 99 Ford F 150 4x4 5.4l. I am having power issues, it just never seems to have as much power as it use to. I have done a lot to it already...I replaced the fuel filter, air filter, changed plugs and COP wires. I took apart the Throttle Body and cleaned it out and that didn't seem to help either. I ran sea foam through the vaccum line that connects to the brake booster. (local mechanic recomended??) I have ran premium, put in fuel additives you name it. I also checked the vaccum pressure and it seemed in line with specs. I checked the fuel pressure and that seemed right along with specs to. I have checked for codes and got nothing. I did the KOEO test and the KOER test and nothing. The only thing on this that looked a little out of place was the calc load, at idle it was about 30% and just touching the throttle it would go to 50%. I am not even sure what to do or where to go from here. All help is greatly appreciated.
Alex
Old Jun 26, 2008 | 07:40 PM
LxMan1's Avatar
LxMan1
Welcome tot he forum
Have you tried cleaning the MAF sensor?
Old Jun 27, 2008 | 10:46 AM
crehberg's Avatar
crehberg
Welcome to the forum skcurtdrof. Go with Jimmy's advice, he knows what he is talking about.
Old Jul 2, 2008 | 04:04 PM
skcurtdrof's Avatar
skcurtdrof
Yup I cleaned the MAF sensor and the TB.
Old Jul 11, 2008 | 11:50 PM
greenmachine53's Avatar
greenmachine53
If cleaning the MAF doesn't work check the cat. converter. I've run into this before where one or more would be plugged(partially or fully) And not set a check engine light. Just my 2cents
Old Jul 12, 2008 | 11:10 AM
Club Wagon's Avatar
Club Wagon
A good way to "check the cat. converter" to see if they're plugged is by using the lower hose off the EGR pipe to the DPFE to look for excessive exhaust backpressure. Unfortunately I don't recall the specs.
