General Automotive Discussion
Ford may keep building Ranger
Old Jun 26, 2008 | 09:14 PM
rebocardo's Avatar
rebocardo
V-6 2.9L engines were "particular", same as the I-6 300 was known for ticking. Both engines with a min. of care were good for 200,000+ miles easy.
imo, The reason most 2.9L engines blew head gaskets were because people don't do regular PM and ignore bad fan clutches. Sure, the heads could use improvements, but, stock, they were just fine.
Old Jun 26, 2008 | 11:49 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by 85e150six4mtod
Where oh where is the Eco-boost 4 for this truck?
I would look under the hood of an 09 Mazda 6 for engine options...
Old Jun 27, 2008 | 08:40 AM
Bart99GT's Avatar
Bart99GT
Originally Posted by fireball 440
Some of them did have head gasket issues and tranny issues with higher milage, but they did have good power and milage for the Ranger.
I had an 86 Ranger 2.9 that went 210,000 before being retired, never been apart.
Ford should have just left the C3 or C4 behind that motor and forgone the A4LD until they had a transmission that was better suited for a truck. I never had a problem with the engine itself, apart from the valve cover gaskets leaking, which was a common and fairly easily fixed problem.
I had a Bronco II that blew up because of that POS transmission. I had to tow a 2900 lb car (well within its towing capacity) for a few miles and a couple of weeks later the thing starts blowing seals at the input shaft and starts slipping. Given that to rebuild or replace the existing POS was more than what the truck was worth, I just ended up selling it. Its a shame, because I really liked that Bronco. It would get 20-21 mpg on the highway, which wasn't bad since I regularly drove 70-80 miles a day for work.
Old Jun 27, 2008 | 09:06 AM
ghunt's Avatar
ghunt
Originally Posted by Octane
Look at it this way though, as outdated as the Ranger is, it still outsells the Chevy Colorado.
Probably because the colorado is an ugly little turd with a crappy engine.
Old Jun 27, 2008 | 10:04 PM
Krochus's Avatar
Krochus
LOL that's like bragging about being the smartest kid in special ED class.
Old Jun 27, 2008 | 10:37 PM
rebocardo's Avatar
rebocardo
I agree, maybe they should have made it HD instead of LD.
Not enough cooling? I know my automatic lasted 150,000+ in one of mine doing firewood and plowing, but, it had a cooler in front of the radiator. Not sure if that was standard.
To save the Ranger in its current form they should just stick a diesel in the engine options and allow both an automatic and manual option. Though I doubt they have any small engine that could met the new emissions specs.
I agree, 4 cyl, 4x4, 5 speed is a sweet combo. You see requests on CL every once in a while for people looking for them.
Old Jun 27, 2008 | 10:53 PM
rangerfan's Avatar
rangerfan
The Ranger gets the same fuel milage as the F-150 so I don't see the point in the quoted reasons. 21 city - lol yeah right maybe the 2WD 4 cyl but the V6's are just as bad as the full sized trucks for mpg.
My 3.0 with 4:10 rear gets 20 city. That's all I drive is city. Auto transmission also.
Old Jun 28, 2008 | 06:20 AM
fireball 440's Avatar
fireball 440
2WD very possible but not in a 4X4.
Old Jun 28, 2008 | 10:40 AM
osbornk's Avatar
osbornk
My brother had one several years ago and it was a pig. It had difficult maintaining speed on the interstate and sucked gas at higher speeds. It was OK if you weren't in any hurry, never hauled anything and didn't hit any hills.
Old Jun 30, 2008 | 08:28 AM
Bart99GT's Avatar
Bart99GT
Its hard to compare the old 90hp 1bbl carb 2.3L to the newer 150hp FI version. Heck, even my '95 2.3L performed better than those old carb'd engines, despite only having an extra 15 hp or so.
Today's 2.3L and 4wd wouldn't be a bad combo. I think it would pretty much do in the 3.0L if Ford were to do that though.
Old Jun 30, 2008 | 11:31 AM
wendell borror's Avatar
wendell borror
I reported this on the ranger forum after reading it on blue oval news. It's a smart move as it will fill the gap that would be left if they stoped making it after this year. The new world ranger isn't going to be ready to go untill 2012. They should make a 4 cylinder 4x4, the duratec has more power than the lima had when you could get it in a 4x4. I would love to have a little bare bones 4 cylinder 4x4 with manual trans for work and I'm sure a lot of others would as well.
Old Jun 30, 2008 | 11:43 AM
ghunt's Avatar
ghunt
If you could get a 4 cyl, 4x4, 5 speed Ranger with AC for a decent price, I'd get one for a daily driver, no question.
Old Jun 30, 2008 | 12:26 PM
  #28
BigF350's Avatar
BigF350
FTE Emeritus
I think it might be available a bit before then
Old Jun 30, 2008 | 01:54 PM
  #29
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If Ford were smart, they'd put the Ranger on a diet to lose about 500-700lbs, then drop in a small 4-cyl diesel with a 5-6 speed. I'd buy one.
Old Jun 30, 2008 | 02:06 PM
  #30
BigF350's Avatar
BigF350
FTE Emeritus
Don't think they won't... I don't know about the 500-700lbs though.
Getting through current safety/emissions/NVH requirements with that amount (or even ANY) weight drop is near impossible.
Check bottom of page...
http://www2.fordconnection.com/fordc...wenginespc.htm
