'95 Explorer front Dr Shaft worn out
Old Jun 25, 2008 | 02:55 PM
jbyrd's Avatar
jbyrd
My front drive shaft (95 Explorer 4x4, 4 door),started a bad vibration and after removal tried new u joints that did not help. learned that the thing with 2 ujoints (forgot the name but it says Spicer in it), neads replaced as it has a ball joint in it worn. Question is can I replace or repair the spicer joint, cant afford a new drive shaft right now. any answers appreciated.
Old Jun 25, 2008 | 10:04 PM
jbyrd's Avatar
jbyrd
Just found out it's called a Cardone joint? anyone know anything about it? is it fixable? Autozone, Advance say get the whole drive shaft for 2-3 hundred, but I only need the little cap that goes on it, hope this makes sense, thanks all.
