HO cam swap on SD system
Old Jun 25, 2008 | 12:51 PM
currituckF150's Avatar
currituckF150
What is the procedure for correcting the injector firing order for a HO cam swap?
Old Jun 25, 2008 | 02:32 PM
alxsnmr's Avatar
alxsnmr
No need to do so on a Speed density system as it is a Bank fire system not a sequentially fired system as the later injection systems.
Old Jun 25, 2008 | 03:52 PM
currituckF150
I realize that it is a bank fire system but I thought that the different firing order required a different grouping of injectors for firing to match.
Old Jun 25, 2008 | 03:58 PM
EPNCSU2006's Avatar
EPNCSU2006
The injectors are grouped the same (1,4,5,8 and 2,3,6,7) on both the 302 and 351 speed density systems.
Old Jun 27, 2008 | 09:36 AM
alxsnmr's Avatar
alxsnmr
Sorry for the incomplete statement, but you only need to correct the spark plug firing order to match the cam.
