351W Installation Questions
Old Jun 24, 2008 | 05:47 PM
Woodsman_30350's Avatar
Woodsman_30350
I am trying to get ready to fire up a 351W in my "50 F1. I connected the upper and lower radiator hoses today and noticed there are two nipples in the water pump on the upper left quadrant. The is a similar nipple in the thermostat housing just to the left of the large neck. I know hoses attached to these ports but can anyone fill me in with more detail.
Also, when I removed the distributor, I marked the positioning on the block but being the newbie I am I tried to turn over the crank with the plugs remove to test things out. Now I am cooked. What can I do to get things lined up again.
Any help is appreciated.
Old Jun 24, 2008 | 07:01 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Those hose outlets go to the heater core via the firewall.
Just turn the engine by hand until the timing mark is just past 0* on the #1 compression stroke. With the valve cover off it's easy enough to figure out. Then just mark the #1 terminal on the dizzy and install with the rotor on your mark.
Old Jun 24, 2008 | 07:46 PM
Woodsman_30350
Any idea on the one nipple next to the large radiator hose outlet on the thermostat housing?
Old Jun 24, 2008 | 10:24 PM
BaronVonAutomatc
IIRC, there's one on the manifold that goes to the heater core. Then another hose back from the heater core to the pump, and a small ell-shaped hose from the thermostat housing to the pump as well.
Old Jun 24, 2008 | 10:35 PM
Woodsman_30350
I thought the lower of the two on the water pump goes to the heater core. I guess not. Where is the fitting on the manifold for the hose to the core?
Old Jun 25, 2008 | 03:19 PM
BaronVonAutomatc
Okay, you are correct - the lower WP connection goes to the heater core and the upper uses a short ell-shaped hose to connect to a fitting next to the radiator hose coming off the neck on the intake manifold. Behind the WP neck on the manifold is a tapped opening into the water passage, there should be a hose fitting there that connects to the heater core. The tapped opening on the other (driver's) side of the manifold is for the temp sending unit.
Old Jun 25, 2008 | 04:24 PM
Woodsman_30350
That is the last piece of info I needed Baron. Thanks a bunch. By the way, when I fire it up, do you think I can just loop from the lower W/P fitting to the manifold until I install my heater.
