ya, but those are at best estimates.
same with vac. gauges. but if you get one that monitors injector pulse width and vss signal, you have a very accurate reading.
Where did you see that at? It says it works on diesels but a lot of things say that and don't. Ill keep looking and see what I can find. You got me interested and now I kinda want one.
it would be really nice to have!
it is based off of computer only- on the newer engines they come with vac gauges (sometimes known as mass air flow sensors) that it can tap into.
on newer diesels the computer incorporates boost into the reading, allowing the computer to work.
there's a compatability list on the site, and says 96 fords except with diesel engine...
I found a site with guys who made them for a Geo... same idea, MUCH smaller injectors. but it had to have a computer or tablet with a program to translate the data... I just want a gauge..
There is a application chart but I cant download it here at work. It is in the order/contact link. It is kinda exspensive $239 plus $30 for the buzz test option
