Does this recipe sound right??
Old Jun 26, 2008 | 03:29 PM
empiretc's Avatar
empiretc
Originally Posted by fabmandelux
And I would never run "raw" biodiesel.....................
me neither.
take a little of that lye and put on an o-ring. it will change your mind about running unwashed diesel.
Old Jun 30, 2008 | 09:59 AM
KyleG's Avatar
KyleG
hey did i tell you how i am running the fuel....I am filtering the fuel after the processing. I know everyone probably does that, but since i am not washing my fuel yet i just have been filtering it down with a 0.5 micron filter and then pump it right in the truck. My father is probably getting a 2000 F-350 with a 7.3, beautiful truck, but i am gonna wash and test the fuel before running it in that truck.
Old Jun 30, 2008 | 10:38 AM
Phydeaux88's Avatar
Phydeaux88
You cannot filter out dissolved Naoh or KOH. They are quite corrosive and will attack metalic parts of you fuel system.
You wont get residual glycerol witn a .5 micron filter, the molecule is smaller than the BD molecule so if the large one passes the smaller will obviously pass.
You wont get FFAs with a .5 micron filter they are about the same size as BD molecules.
You wont get residual water with a .5 micron filter.
Mix FFAs, water, and NaOH together - aggitate by driving and you get a fuel tank full of SOAP.
Old Jul 1, 2008 | 01:15 PM
KyleG's Avatar
KyleG
well is it easier to water wash my fuel or dry wash with magnesol?? I just need the easiest way to do it.
Old Jul 1, 2008 | 07:28 PM
empiretc's Avatar
empiretc
they are both a pain in their own respect, but dry wash (magnesol) is the way to go!
Old Jul 3, 2008 | 10:53 AM
KyleG's Avatar
KyleG
Well Ive seen different websites that sell it by the 50 lb. bag for about 80$ a bag....now that wouldnt be bad if you would only use a small amount of it for every batch. How much do you use for every gallon of fuel?, and do places like home depot sell it? But I think I know how its done, All I do is after I drain the glycerin out of my batch of fuel, I add however much magnesol I need in my processor and let it mix for a while, then just filter it out with a 1 micron absolute bag filter. Right? I am sure i am missing some information, but it does sound easier than messing with the water.
Old Jul 3, 2008 | 11:01 AM
KyleG's Avatar
KyleG
One more thing, I made about 3 small batches of fuel and they didnt come out yellow, more of a light brown. I am unable to see through it too. can you possibly tell me what i could be doing wrong? But it does still run in the truck...and it is unwashed.
Old Jul 3, 2008 | 01:26 PM
empiretc's Avatar
empiretc
without methanol recovery, you need to use 2% by volume. i.e. ~6 pounds of magnesol for 40 gallons of bio.
you are brave running that stuff in your truck now. sounds like you are not using the right amounts in your process.
Old Jul 4, 2008 | 07:15 AM
Wieckster's Avatar
Wieckster
the color difference is from different kinds of oil that you collect
not every batch of fuel will look the same
Tugly
Dec 12, 2018 09:31 AM
pawpaw
Oil & Lubrication
May 13, 2016 12:59 AM
Encho
May 19, 2015 08:15 PM
Macrobb
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jul 12, 2014 06:20 PM
Pete P.
Large Truck
Feb 24, 2011 11:28 AM
