posts I started about carb....WATER
I took it back to the shop, he popped the line and let the little bit run into a glass, there was water. He let me use a bay, I dropped my tank {had about 1/2 tank}
I was using a drinking glass to get it out and put it in a gas can, and some into a 5 gal. bucket......outta the 1/2 tank, I'd say a gallon of it was water.
So....new question, I assume this is from the cheap Pakistan store I get my gas from, {$3.92 a gallon} I also fill up my Tahoe which has fuel inj.....does it not effect injectors the same way as a Carb??
The problem with water is it sinks to the bottom of the tank and just sits there till you jostle the tank around. If you run a gas treatment in the fuel, it will pick the water up and run it though the engine(though with that much water you did the right thing pulling the tank).
