Sponsored by: Real Truck
12volt Battery source?
Old Jun 23, 2008 | 10:06 AM
HeavyAssault's Avatar
HeavyAssault
Where can I pull 12v off one of the batteries? Can I connect to the secondary fuse panel under the hood? I would prefer a connection on the driver's side if possible.
I tried to connect up my Accuvolt this weekend and blew the fuse. I figured the point where I connected must have been 24v since the fuse blew on the Accuvolt. The Accuvolt needs 12v to feed directly off a battery, as close to the battery as possible.
Old Jun 23, 2008 | 11:43 AM
elee3's Avatar
elee3
There shouldn't be any 24 volt on your truck. The two batteries are connected in parallel.
Old Jun 23, 2008 | 07:23 PM
toolman05kr's Avatar
toolman05kr
remove the cover from the secondary fuse panel, next to the master cyl. on the rear of the box, towards the firewall there is a 6mm stud. It's 12 volt at all times and is a good sourse
Old Jun 24, 2008 | 08:21 AM
HeavyAssault
Cool I figured that would be a good spot..thanks.
Old Jun 24, 2008 | 08:40 AM
toolman05kr
Glad to help, By the way, make sure to use an in line fuse or circuit breaker . good luck and enjoy.
steve(ill)
1997 - 2003 F150
Mar 13, 2013 02:10 AM
finerhomes
Sep 6, 2012 08:34 AM
gmacuajo
Electrical Systems/Wiring
Apr 23, 2012 07:12 AM
wparente
Aug 26, 2006 02:06 AM
