Valve noise on driver's side
Old Jun 22, 2008 | 02:42 PM
billfishnut's Avatar
billfishnut
My wife's 2003 explorer (4.0sohc) is making valve tapping noise on the driver's side. I searched this forum and found out about the tenisoner problems with the earlier engines. I have removed, cleaned and reinstalled both of the tensioners for the cam shafts but to no avail the tapping still happens between 2500 and 3500 rpm (loaded). I used a stethascope and it sounds like the valves on the drivers side are tapping.
Truck has 80k+ miles and is driven to work and back and errands. Oil has been changed every 5000 miles with conventional 5W30. We run 87 octane. I have "seafoamed" the intake side and had no change.
Any one had any experience with this?
Old Jun 22, 2008 | 06:55 PM
srercrcr's Avatar
srercrcr
They usually clear up on their own like in a months time. If not, an easy Step One would be to run some Engine Flush in the oil before draining the oil. I usually recommend a lighter oil too to fix it but your oil is already pretty light.
Old Jun 23, 2008 | 08:18 AM
billfishnut
THX, I spoke with a buddy of mine who thinks it may be a lifter. I will try some engine gunk or something to clean it out before climbing inside the valve cover.
Old Jun 23, 2008 | 09:32 AM
Bear River's Avatar
Bear River
Former ******
Use a product called AutoRX. Is that is not available, try Rislone. Also for future reference, don't use Fram oil filters. They are know to cause lifter problems on a lot of makes and models due to small fibers coming loose from the media and getting stuck in the lifters and other small oil passages.
Old Jul 1, 2008 | 07:15 PM
BJWinter's Avatar
BJWinter
Bear, are you recommending the Rislone engine treatment or do they also make an engine flush? I checked at AutoZone but all they had in that brand were an oil addititive engine treatment and one which was meant for restoring compression.
Old Jul 1, 2008 | 09:14 PM
srercrcr's Avatar
srercrcr
AZ has Engine Flush in a one qt can, usually down low.
Old Jul 1, 2008 | 09:26 PM
BJWinter's Avatar
BJWinter
Thanks for the tip. I expected it to be with the engine treatments.
