Power Locks not working?
Today i took the panels off both front doors and looked around for any problems or disconnected wires, and found nothing...
Except that the passenger power window hasn't been working 'cuz the motor died.
I hooked up a multimeter to various areas and pushed the switches, and i get no read outs at all~so im getting no power to the switches apparently.
any ideas?
These door lock motors are not push-pull solenoids even though they sound like solenoids. They are actually small DC can motors with commutators and brushes, like on toy cars! You may as well get used to working with them. My experience is that due to poor placement (shaft pointing upwards), water coming in around the window felt will track down the shaft and directly into the motor (the protective shield cracks with age). That will eventually cause the motor to freeze up. Unfortunately, the motor is a crimped case design, so getting into them is very difficult. It is kinda a "birch" getting the motor out of the holder, without drilling out the big rivet for the holder.
See if you can reach the motor and manually move the arm that connects to the motor shaft. I betcha its frozen up-----unfortunately
If you're not getting any voltage at the switches, the problem could be the common one; a break in one of the wires going through that tube between the door and the body.
One thing for sure, a Ford owner should either get very familiar with door lock motors and the window motor gear assy's or have DEEP pockets
. Glad to hear you fixed your problem
One of the contributing causes to my motor's failure is a worn out weather strip. There is a piece along the outside of the window opening that rubs against the glass which had completely disintegrated, so it was letting all water hitting the window to get into the door. I found another in better condition at the salvage yard, and replaced my worn out one. A quick test with the garden hose showed that it was keeping most of the water out, and no longer raining down onto the lock motor.
