Horn button removal
Old Jun 21, 2008 | 01:29 PM
caspery's Avatar
caspery
Question Horn button removal
OK Guys... I want to do this right. I'm pushing down ,evenly, on the horn button and turning counter-clockwise and, and... nothing happens. The button just spins. This is a 4-spoke wheel, floor shift 1966 F-260 4X4. Any tips? I have to check out the turn signal switch. No brake lights.
Old Jun 21, 2008 | 03:40 PM
drof46's Avatar
drof46
You saying you can spin the horn ring all the way around (360)?
Old Jun 22, 2008 | 12:20 AM
don merke's Avatar
don merke
Question
i think i got hijacked [4 spoke? not org. wheel org. is 3spoke thats that problem [brakes check brake light switch back of brake pedal /or faulty wiring /corrosion /loose connections ect,
Old Jun 22, 2008 | 03:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by don merke
[SIZE=2]i think i got hijacked [4 spoke? not org. wheel YES, IT IS! org. is 3spoke NO, IT IS NOT!! thats that problem [brakes check brake light switch back of brake pedal /or faulty wiring /corrosion /loose connections ect,
The 4 spoke steering wheel is original and correct for a 1966 F250 4WD, and other 1961/66 models.
C1TZ-3600-A .. 4 Spoke Steering Wheel-Black-18" Diameter
C1TZ-3600-B .. 4 Spoke Steering Wheel-White-18" Diameter
Fits: 1961/65 F100/250 4WD / 1966 F250 4WD / 1961/66 F350.
1961/66 F100/250 2WD's & the 1966 F100 4WD use a 3 spoke wheel that's 17" in diameter.
Old Jun 23, 2008 | 08:46 AM
caspery's Avatar
caspery
Buttom spins 360
Yes the horn button spins 360 degress.
It does ease up when the top of the buttonis facing the bottom of the wheel.
Old Jun 23, 2008 | 03:14 PM
don merke's Avatar
don merke
there is a 3 tang on the bottom of horn button and a 3 slotted retaining ring on the st. unit turn 33 1/2 degrees ether way of top dead center /wiggle and jiggle ! it will come up 3/4 spoke should be the same not to fear can't break it iv'e done it many times no problem /look in a break down of a steering assembly to show how it is attached [ps. get a manual on your truck would help[ if all fails get out a crow bar that will work to!! [ note# tangs could seperate fr. button should turn not spin ? freely]
Old Jun 23, 2008 | 03:20 PM
don merke's Avatar
don merke
IF the screws are screwed that does it]
Old Jun 23, 2008 | 03:29 PM
caspery's Avatar
caspery
I'll try it
Thanks Don, I'll try the 33.333 of a turn and it should work. I do have the CD assembly catalog,too.
Old Jun 23, 2008 | 04:11 PM
don merke's Avatar
don merke
Thumbs up
from LMC PARTS -CD? DEADLY HOW DO THEY WORK OUT / IN-DETAILS/GRAPHICS [PS -V8 OR 6 BUTTON SAME YOUR ENG.IS ?
Old Jun 23, 2008 | 04:22 PM
caspery's Avatar
caspery
Master Parts & Accessories Catalog
I got this CD from HiPo Parts Garage www.hipoparts.com. 22.95. A copy of the factory catalog. Lotta info. Some wiring info. Details about the emergency flasher systems.Etc, etc,. Well worth the money.
Old Jun 23, 2008 | 07:50 PM
don merke's Avatar
don merke
Cd Plus
Sound Good!!ive Been In The Automoto Bus. 40. Yrs.mecanic /driver/collector Cars Trucks /tons Of Manuals/computer Stuff But Will Have To Try Cd Input >.one Of My Merc's Is 65 1 Ton4x4 Dully Napco Cause Ford Didn't Make 1 Tons 4x4's They Did 3 By Napco Group I'm A Member Of [to Find And Sell Parts Through> 79/80 Info Out Of My Fix Your Ford Series [ 65/80 Excell. Little Manuals Great Info>detail/stats.a Must For Starting And Advanced Repair!!call Anytime Thread Ha Ha See Ya As We Say In The Cariboo B.C[PS. MY FLASHER IS IN THE GLOVE BOX>ON MY[67 MERC. 250 CS THAT WAS FUN FINDING IT TOO !! OVERTIME
Old Jun 23, 2008 | 08:30 PM
camperspecial65's Avatar
camperspecial65
If the lights just quit working recently try jiggling the connectors on the switch which is in front of the master cylinder...2 wires with 90 degree elbows that slide on to the round brake light switch prongs. Or take the wires off and clean the prongs on switch to be sure of good contact. If thats all done, check the fuse on the left side under the dash inside the cab.
If the fuse is good...again..clean/check for good connections on the ends...sometimes fuses can pop and the fuse looks fine but continuity is broken due to the break being at the end of fuse. If you have a continuity checker, you can check that easily.
If all of this checks out ok...I would get a new switch, or if you have another one kicking around, try swapping it out and seeing what happens.
If all else fails, go get another switch at NAPA...10-15 bucks or so max i would gather.
I hope this helps, cs65
Old Jun 23, 2008 | 08:35 PM
camperspecial65
Don Merke...the flasher units are usually located to the left of the ashtray..sometimes they are just hanging, sometimes they are in a holder.
- cs65
Old Jun 23, 2008 | 11:52 PM
don merke's Avatar
don merke
THE ONLY THING NEXT TO THE ASHTRAY IS THE LIGHTER I'M GOING FOR A SIG MY 65 M 350 4X4 3 MADE BUSHY NAPCO NON CUSTUM CAB CAME WILL FLARES IN THE UNDER THE FOOR BATTERY COMPARTMENT WEEEEE THAT WAS A LONG WORD O THINK I'LL HAVE THE GRIZZ STEW AGAIN TO KE UP MY STRENGTH PS I ONLY DRIVE WHAT EVER IN THE DAY TIME NOW CS.65 IS ON TO IT FIND THE MISSING THEN GO FOR A SHORT[CAMERO KILLER@JAKE THE SNAKE SEE YA
Old Jun 24, 2008 | 12:35 AM
Jimbo302's Avatar
Jimbo302
I didn't understand any of that.
