my headlights dont work??
Old Jun 21, 2008 | 12:43 PM
pipman76's Avatar
pipman76
Exclamation my headlights dont work??
i had just finished converted my truck from air too non air,i used the whole wire harness and heater box from donar truck,my problem is there is no power to the front head lights when i turn the light switch on the tail light work and the fron parking light work as well with a testor there is no power at the headlight plug,ive checked fuses also.where do i need go from here
Old Jun 21, 2008 | 02:20 PM
jimlj's Avatar
jimlj
Check your dimmer switch
Old Jun 21, 2008 | 02:45 PM
pipman76's Avatar
pipman76
alright thanx ,i do it and let u know jimlj
Old Jun 21, 2008 | 03:06 PM
pipman76's Avatar
pipman76
the dimmer switch is plugged in and still no head lights do u think the dimmer switch could be bad??i have another one i can try
Old Jun 21, 2008 | 03:49 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Check for power at the Red/Yellow wire at the dimmer switch with the headlamp switch in the on position.
If power, check for power at either the green/black, or red/black wires, depending on how the switch is "switched" if no power to either wire... replace dimmer switch.
If no power to red/yellow wire, check the connection at the headlamp switch where the red/yellow wire comes out. if power you have a wiring fault between the headlamp switch and dimmer switch.
If no power replace the headlamp switch.
Old Jun 21, 2008 | 07:12 PM
pipman76's Avatar
pipman76
i took the dimmer switch out of my donar truck and you guys were right it was a bad switch everything is A -ok now thanx guys,its always good to be in the presents of fellow FOrd lovers
