2000 f250 6 speed problem
If you're clutch is going out then you should feel it slip (or at least notice the rpm jump without a corresponding increase in speed). If you don't feel the clutch slipping, then you probably have problems with the hydraulics. Is the reservoir for the clutch hydraulics full?
If the hydraulics are going out, you can buy a pre-bled master / slave assembly from ford for between $150 - $200 (maybe less from one of our ford sponsors) and change it yourself in less than an hour. It's a simple plug and play set up. If you need instructions on how to change it let me know.
To change, take a pair of channel locks or large pliers and rotate the slave cylinder 1/4 turn CCW where it attaches down next to the tranny. The slave cylinder just pulls out of the hole, BUT, there is a small plastic piece on the end of the rod coming out of the cylinder. If you tilt the slave cylinder down just slightly and SLOWLY pull it out far enough you can stick your finger in and hold this plastic cap on the end of the rod to remove the slave.
The reservoir has those little plastic tabs holding it in place. If they don't want to come out just cut them off so you don't break the holes out on the piece by the windshield.
Now if you remember the spring on the pedal I mentioned earlier, if the clutch pedal stays on the floor when you start playing on the inside, a slight bump will cause the pedal to fly up and hit you in the chin.
The rod on the master just slips over a **** sticking off the side of the clutch pedal and is held in place with a plastic clip. If you slip a screwdriver between the plastic clip and the end of the know you can just slide the rod off of the pedal. The pedal will now come up farther toward the dash since it's disconnected.
The last step is to disconnect the master from the firewall from the engine side. Another 1/4 turn CCW with a pair of channel locks and it will slide out of the hole.
Now just reverse the procedure and the new one is installed. The plastic cap on the slave is molded to hold the rod in the cylinder until you push the pedal the first time after installation. You'll see what I'm talking about after you look at the parts.
A very simple procedure. Ask your dealer what they charge to do this, then prepare to be shocked after you do it yourself and realize how much money you just saved for doing something so easy. Then you'll understand why FTE is such a great place to hang out on.
Any other questions, or if any of that was confusing let me know.
