Sponsored by: Auxito
IAC Valve
Old Jun 20, 2008 | 11:27 AM
makthenif's Avatar
makthenif
IAC Valve
Can someone tell me where the iac valve is located on my 2000 F150 4.2? Also, what is the best method to clean it? Thanks
Old Jun 20, 2008 | 07:14 PM
grandfunknut's Avatar
grandfunknut
ON top or around the throttle body area,should have 2 10 mm bolts to hold it in place....hope this helps,this is a cheaper part at a NAPA store rather than at FORD....
AzBlueWolf's Avatar
AzBlueWolf
https://www.ford-trucks.com/forums/1...tml#post877960
very similar to the v8...right near the throttle body
Mark
Old Jun 20, 2008 | 07:16 PM
grandfunknut
Use solvent and blow clean with air I spray a little penetrating fluid in both ports.....
Old Jun 20, 2008 | 07:44 PM
galaxie641's Avatar
galaxie641
IF it is alike the modulars, and I think it is, it is behind the TB on the back of the elbow. A major PITA to get to but at least there are only 2 bolts.
Old Jun 20, 2008 | 09:35 PM
LxMan1's Avatar
LxMan1
They actually take an 8mm socket or wrench.
Old Jun 21, 2008 | 10:17 AM
makthenif's Avatar
makthenif
thanks guys.
