What happened????
Old Jun 19, 2008 | 06:40 PM
MAXSD250's Avatar
MAXSD250
What happened????
I installed a Superlift truespeed sensor calibrator. Wired per instruction sheet that was supplied. Disconneted both -battery cables, did the relearn thing after I was done. Anyway---my interior overhead light does not come on when door open, delayed ACC does not work, chimes do not work with key in and door open, trip odometer resets to zero with every shutdown, and the list goes on. Any ideas what I might have done wrong?
Old Jun 19, 2008 | 06:51 PM
OZX1's Avatar
OZX1
Although not even close to being directly related, I recently had very strange electrical behaviors along the same wacky scale due to selecting an incorrect ground source when adding a load balancer to my signal light circuits. Is there a chance that you too have selected an isolated ground source that is causing a referent issue like I had? My issues went completely away once I figured it out and used the correct grounding source...
Old Jun 19, 2008 | 07:03 PM
MAXSD250's Avatar
MAXSD250
Well that's certanly someplace to start looking, will do that tomorrow after work. Thanks
