New User from CA
Old Jun 19, 2008 | 01:10 PM
Red Eagle's Avatar
Red Eagle
New User from CA
I have an F350 7.3 diesel that ran fine, started, died and now won't start. I had taken it in for a cam position sensor replacement (racall), drove it home. I have since re-replace the cam sensor as an inexpensive test. It still won't start. The wait to start light comes on & goes out. The glow plug solenoid checks out, there is power to the outgoing brown and yellow wires. Two codes show up 0562 (low power but that is with the enging not running) and 1396 (glow plug sensor on bank 2). I understand that that will cause a check engine light to come on but not a No-Start condidtion. I tried starting when switched to each of the fuel tanks (assuming that there is a pump in each one). All of the fuses in the panel test OK for continuity (in place, I haven't pulled them). I did pull the breakers and the test OK. My alarm system seems to work but I know that it is capable of preventing the engine from starting. I don't know how to test it though.
Also please forgive the post in the reply box. I was unable to locate the "Post" button.
Old Jun 19, 2008 | 01:13 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
Hi Red Eagle welcome to FTE the BEST of the rest
You should post your questions in one of the site's tech forums which are located at this link,,, Ford Truck Enthusiasts Forums - Ford truck and SUV owners and enthusiasts Community And Information Source.
You may want to look here,,, https://www.ford-trucks.com/forums/forum107/
Or here,,, https://www.ford-trucks.com/forums/forum170/
What year truck do you have?
FTE has a local chapter for California members which you can find at this link,,, https://www.ford-trucks.com/forums/forum163/
Great to have you as a member.
trike1946
Nov 23, 2008 09:29 AM
