Sponsored by: Auxito
97 tps?
Old Jun 18, 2008 | 10:03 PM
hucka1a's Avatar
hucka1a
97 tps?
Hey Guys,
I am trying to find some info for a buddy of mine. He's got a 97 F150 4.6 4x4 auto. It idles way down when coming to a stop, and sometimes it dies. I told him it sounds like the throttle position sensor. He took it to a mechanic today, and he told him that he thought that the #6 cylinder is burnt??? I'm no mechanic, and I no nothing about a 4.6. But if this is as serious as a cylinder or piston, wouldn't the truck be missing or smoking?
Thanks
Old Jun 18, 2008 | 10:07 PM
galaxie641's Avatar
galaxie641
Could be a simple vacuum leak. IAC's usually go bad before the TPS does but vacuum leaks are the most common idling issues.
Old Jun 19, 2008 | 10:57 AM
KingRanchMan02's Avatar
KingRanchMan02
I'll second the IAC valve as the source of the problem. Good luck!
Old Jun 19, 2008 | 05:03 PM
projectSHO89's Avatar
projectSHO89
Galaxie's advice is spot-on.
Check the PCV elbow for failure.
If it's okay, the IAC valve is probably gummed up, an extremely common problem for most Fords of this vintage. Cleaning the valves sometimes helps, at least temporarily. Usually, replacement is needed, though.
Steve
Old Jun 20, 2008 | 06:20 PM
hucka1a's Avatar
hucka1a
Thanks alot guy's. I'll be sure and tell him.
Thanks again
Old Jun 20, 2008 | 07:09 PM
grandfunknut's Avatar
grandfunknut
I just fixed this same symtoms on my sons truck,iac was okay,no codes,the NYLON ,double elbow line under the throttle body to left valve cover was sucking air on 1 or both connections,I installed a hose with clamps and she idles smooth again....GOOD LUCK
JayzDaddy
1997 - 2003 F150
Jun 3, 2013 09:00 PM
Tennesseestorm
2004 - 2008 F150
Feb 2, 2012 08:26 PM
97Fordfan
1997 - 2003 F150
Jul 20, 2010 08:46 AM
XylemXorro
1997 - 2003 F150
May 10, 2005 06:31 PM
Tim Ervin
Modular V8 (4.6L, 5.4L)
Oct 18, 2003 05:52 PM
