glow shift gauge q's?
Old Jun 18, 2008 | 02:07 AM
hawaiian-style's Avatar
hawaiian-style
looking to get a pillar gauge pod with 3,one of them may be air/fuel which requires narrow band oxygen sensors...does a 92 f150 iL300-4.9L 4x4 have this feature or not?also would this gauge be of any use or importance?,just need to fill that third space.ha.what would be a good third gauge to go with?
planning on going with vacuum,water temp.,air/fuel...
what gauges would you guys suggest i go with?
thanks
Old Jun 18, 2008 | 02:12 AM
hawaiian-style
options are
my options are...
voltage-have in stock cluster
air/fuel
oil temperature
oil pressure
water temperature -have in stock cluster
vacuum pressure
tachometer -have in stock cluster
trans temperature
fuel pressure
thanks for any advice
Old Jun 18, 2008 | 02:25 AM
86F150302's Avatar
86F150302
I would do
oil pressure
oil temp
trans temp
Old Jun 18, 2008 | 04:37 AM
EPNCSU2006's Avatar
EPNCSU2006
You're not going to be able to change the air fuel ratio, so your gauge will mainly just be something flashy to distract you from driving. I would monitor oil pressure (since the stock gauge is merely an on-off pressure switch) and water temperature for sure, then for the third I would suggest oil temperature or transmission temperature if you do a lot of towing or heavy hauling, or vacuum if you do a lot of empty driving and want a way to monitor engine load to assist with maximizing fuel economy.
Old Jun 18, 2008 | 05:51 PM
lostin90s's Avatar
lostin90s
Originally Posted by 86F150302
I would do
oil pressure
oil temp
trans temp
Right on the mark ..
These r good guages
Vacuum and air mix .. These ones listed will keep better tabs on things . The oil presure in stoke dash r not the best . The temp water guage is not to bad .
Trans temp (for the e4od ) Is almost a must . Same with oil temp and presure.
Old Jun 19, 2008 | 02:23 AM
TexasGuy001's Avatar
TexasGuy001
I would do temp oil and trans temp.
