Pulling a 7.3 ?
Old Jun 17, 2008 | 06:44 PM
WHITEPOWERSTROKE's Avatar
WHITEPOWERSTROKE
Pulling a 7.3 ?
Ok, I got the tranny separated and pulled back. . . I have the wire disconnected, fuel line, and starter off and radiator out . I took out 4 motor mount nuts off the bottom of the frame mounts, lifted it up and and started to move it forward, but the pan is hitting the frame. I started to tilt/lean it forward and the turbo hits up under the dash.
Looks like the turbo will need to come off . . .will I need to take the intercooler out also or is there enough room for it if I angle it a little ?
Old Jun 17, 2008 | 06:58 PM
ron's power stroke's Avatar
ron's power stroke
for the price of a IC..i think i would pull it out....you never know when it may slip..
Old Jun 17, 2008 | 08:50 PM
John7894's Avatar
John7894
I think you'll need to pull the intercooler, trans cooler and pop off the upper radiator support too...
