Keyless Programming
"Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located at the base of the steering column. All doors will lock then unlock to confirm programming mode. Press any button on 1st trnsmitter. The door locks will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming."
Instructons vary for other models, but these should be good for any 1994 to 1996 F-Series/Bronco. I hope this helps!
dn.
After posting, I noticed that you included 1997 in your range. These instructions are different, and are also valid for 1995 to 97 Explorers & Rangers, 1996-97 Taurus/Sable, and 1997 Expedition and Mountaineer:
"Cycle ignition from OFF to RUN or ACC 5 times within 10 seconds, ending in RUN or ACC. All doors will lock then unlock to confirm programming mode. Press any button on 1st remote transmitter. Door locks will cycle to confirm programming. Press any button on 2nd remote transmitter (up to 4 transmitters total possible). Turn igniton to OFF. The door locks will lock then unlock to confirm programming."
dn.
