Im still stuck on trying to build my own drop axle, I think I've asked this question before some months back, but am still wondering anyone here ever build thier own drop axle? I saw a program on Speed Channel called Hot Rod TV where a young fellow named Jordan built his own drop axle in what appeared to be a homemade jig and a set of torches. Just wondering If anyone has done this and can lend some advice for a novice at dropping axles.
Thanks Dan
Ahhhh I see now....I think.....your saying that I beams a cast and not stamped steel and without a complete machine shop its not within a shadetree mechanics realm of capabilities.
Thank you
Your input is valued
Dan
check out the article about dropping axles on the HAMB website its really interesting reading and had really good pic's also. why not give it a try because if you screw it up you can always go buy a new one. their is a few guys over on the HAMB that provide the service reasonable.
