Sponsored by: Auxito
gear ratios
Old Jun 15, 2008 | 10:16 PM
fruth04's Avatar
fruth04
gear ratios
hey i looked at my rearend to see if i could figure out my gear ratios.... it said 373 ..2L22 i think?! it was pretty beat up, does that sound ri ght? 3.73s?
Old Jun 15, 2008 | 10:45 PM
galaxie641's Avatar
galaxie641
Yes they came with 3.55, 3.73 and there was a higher 3.08 or some such thing.
Old Jun 16, 2008 | 06:53 AM
96f150's Avatar
96f150
Check your door tag, It'll probably say B6, which is a 3.73 LS diff.....I think 2003 was the first year they offered the 3.73 in the supercrew.
Rich
Old Jun 16, 2008 | 09:25 PM
fruth04's Avatar
fruth04
it says axle:H9 ? i think im looking at the right spot?
Old Jun 16, 2008 | 09:37 PM
LxMan1's Avatar
LxMan1
H9 = 3.55ls
Old Jun 16, 2008 | 09:45 PM
fruth04's Avatar
fruth04
hmmm k thanks
Old Jun 17, 2008 | 02:51 AM
LxMan1's Avatar
LxMan1
3.55's are most common. 3.73 was special order I believe.
Old Jun 17, 2008 | 11:39 AM
tallicakid's Avatar
tallicakid
whats better to have 3.55 or 3.73? I get confused for towing/ normal driving
Old Jun 17, 2008 | 11:44 AM
countryboy116's Avatar
countryboy116
3.73 would be better
Old Jun 17, 2008 | 07:50 PM
LxMan1's Avatar
LxMan1
4.10's even better
Old Jun 17, 2008 | 08:16 PM
AzBlueWolf's Avatar
AzBlueWolf
are you the only owner?
the axle may have been changed out...
jack up the rear end, mark the axle and the tire... 1 full revolution of the tire= either 3-1/2 or 3-3/4ths turns of the driveshaft
Mark
Old Jun 17, 2008 | 08:42 PM
countryboy116
Originally Posted by LxMan1
4.10's even better
OH YEAH well I think he should just get rockwells, then he'd have 6.72 gear ratio, haha honestly though depending on your tire size, if it's a stock or close to stock size 3.73s are good, but if you do alot of towing like you mentioned 4.10s are a good ratio, now if you have upgraded tire sizes then you should consider 4.56s or 4.88s. Not sure if you mentioned what size tire you were running jsut saying.
Old Jun 19, 2008 | 10:52 AM
tallicakid's Avatar
tallicakid
what RPM's are you people doing at 70 MPH? What gears do you have? and tire size?
I am @2000rpm at 70 mph with 265/70 r17
Old Jun 19, 2008 | 04:05 PM
150mudder's Avatar
150mudder
im at about 2000 rpm @ 75mph with 3.55LS and 285/70/r17. if im wrong ill come back and change that.
Old Jun 19, 2008 | 08:34 PM
LxMan1's Avatar
LxMan1
Mine ran about 82mph@2000rpm with 3.55's and 275/60R17 tires.
