Sponsored by: Auxito
Leveling kit?
Old Jun 15, 2008 | 09:28 PM
JHUBB58's Avatar
JHUBB58
Leveling kit?
ok so i am woundering since i already have a 6in suspension lift and a 3in body lift on my truck would it be possible to add a 2 or 3in leveling kit and put 6'' blocks in the rear to add a few more inches so i can fit bigger tires like 42's or possibly 44's?
Old Jun 16, 2008 | 05:11 PM
Bobby82490's Avatar
Bobby82490
Dont use a block that big... esp. if you go offroad.
Old Jun 17, 2008 | 05:28 PM
JHUBB58's Avatar
JHUBB58
im tryin to make this truck into more of a "show/everyday driver" type truck. do you think i would be better off just adding a few leafs or geting new leaf springs
Old Jun 17, 2008 | 07:45 PM
Bobby82490's Avatar
Bobby82490
When you got your lift did you have to use add-a-leafs to raise the rear of the truck? If so you will need new springs, but if you didnt originally use add-a-leafs then now you can.
For the front you might be able to get a little more lift out of the torsion bars... but i dont think that much lift.
Old Jun 17, 2008 | 08:11 PM
AzBlueWolf's Avatar
AzBlueWolf
you have a good ride height now...imo
I think some larger rims with the same size tire would do more to improve the looks...
Mark
Old Jun 17, 2008 | 09:40 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Please, DO NOT go larger than a 4" block in the rear. Blocks are dangerous and will break stuff.
Cut your fenders a couple inches if you want the clearance. Its free, and will keep your COG lower...
Old Jun 17, 2008 | 09:56 PM
countryboy116's Avatar
countryboy116
Imma prolly catch hell for this, but why do want such big tires? The ifs on your truck isn't going to hold up very long to 42s much less 44s. You just sas it and get it over with. And x10000 about not using blocks, especially 6' blocks, a 6" block will create crazy axle wrap issues.
Old Jun 26, 2008 | 08:56 PM
JHUBB58's Avatar
JHUBB58
really the only reason i want to put such a big tire on there is because iv never seen a 97-04 f150 with anything bigger than a 36'' tire and im runnin 38's now and i really just want to have the biggest truck in town lol
Old Jun 26, 2008 | 09:17 PM
AzBlueWolf's Avatar
AzBlueWolf
you can have the biggest truck in town...all you need is the biggest wallet...
Mark
