Need more POWER
Old Jun 15, 2008 | 08:48 PM
trailbay123's Avatar
trailbay123
Need more POWER
Hello all, I have 2001 F- 350 W/ a 7.3l Diesel. All stock. 155,000 miles Automatic, 2WD SRW 3.73 rear. I tow a 2008 30ft. Trail bay V series trailer that weighs 8000 lbs. When i went to get the trailer i got 18 MPG, no trailer, after picking up the trailer, I drove straight home, no water or anything else onboard. I got 8.5 MPG and any kind of a grade up hill made the tranny drop out of over drive @ 1800 RPM to drive or 2700 RPM. is this normal? I would like the truck to stay in OD.
Old Jun 15, 2008 | 08:55 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
You want more power look up 6637 air filter, 4 or 5 inch exhaust, Gauges, and the Dp tuner that should help tons!
Old Jun 15, 2008 | 09:04 PM
hucka1a's Avatar
hucka1a
Check out post #18
https://www.ford-trucks.com/forums/5...confusion.html
Hope this helps
Old Jun 15, 2008 | 09:09 PM
megawatt00's Avatar
megawatt00
Welcome to FTE! You can also check out www.7point3.com
Old Jun 15, 2008 | 09:14 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Every day it gets closer.
Old Jun 15, 2008 | 09:15 PM
big poppa's Avatar
big poppa
When your pulling that much weight your going to loose mpg,s but what nick and the guys said above, all those will help the truck perform more efficiently. Good luck and welcome to FTE.
Old Jun 15, 2008 | 09:16 PM
megawatt00's Avatar
megawatt00
Yes it does!
Old Jun 15, 2008 | 10:59 PM
Lovin7.3's Avatar
Lovin7.3
Sounds like Nick has you on the right track....
Jim, Rick, Is it April yet?
Old Jun 16, 2008 | 11:38 AM
UP_There's Avatar
UP_There
If POWER is what you're after......everybody's posts above will have you on track. FYI though......towing in overdrive is a BAD IDEA. Unless you are on flat ground, causing the tranny to downshift under a load causes major heat, and you should manually take it out of overdrive BEFORE it does it under a load. This will also help your mpg's......lugging the truck down in rpm's causes heat in more ways then one! I towed about 5500lbs this weekend and got 12.9 mpg
Old Jun 16, 2008 | 12:56 PM
miller_feed
Just got another day closer.
