Sponsored by: Auxito
starter relay
Old Jun 15, 2008 | 07:21 PM
calibob's Avatar
calibob
starter relay
Just made a trip into town parked at a friends place and now nothing from the starter where's the starter relay on this 1998 f 150 with the 5.4?
Old Jun 16, 2008 | 03:22 PM
KingRanchMan02's Avatar
KingRanchMan02
Your starter relay is on the fire wall just above the battery.
The starter relay has three wires. One is from the battery(red), one to the starter(red), and the other(tan/red) is from a fuse (hot in start, F21) in the central junction box via the digital transmission range sensor. If you have no voltage out to the starter then check to insure that the tan/red wire is hot in start. If not, then troubleshoot back to the fuse and the DTR sensor. If this is good and there is no voltage on the red wire to the starter, then replace the starter relay.
Good luck!
