Offroad & 4x4
60??? 44???
Old Jun 15, 2008 | 07:06 PM
Ford400Man's Avatar
Ford400Man
Question 60??? 44???
I am looking to but a donor truck for parts, a 79 F250 4X4. The guy sent me pics but doesn't know any info on the front axle. I am trying to get some tag info from him. But can you all distinguish if this is a D60 or a D44HD from the pics?
Old Jun 15, 2008 | 07:11 PM
MBBFord's Avatar
MBBFord
Pics are way to small for me to see.
Old Jun 15, 2008 | 07:17 PM
Ford400Man's Avatar
Ford400Man
Try this:
http://cgi.ebay.com/ebaymotors/ws/eB...260951851&rd=1
Old Jun 15, 2008 | 07:18 PM
RawPower's Avatar
RawPower
x2, can't tell a thing from them.
The only way it should be a 60 is if it had a package that upped the GVW
other than that, only F350's came with them
Old Jun 15, 2008 | 07:19 PM
STGFordCrazy04's Avatar
STGFordCrazy04
thats a 44hd. I can see the j shaped steering arm.
Old Jun 15, 2008 | 07:39 PM
iggybob44's Avatar
iggybob44
Hopefully your trying to buy a parts truck from someone who just honestly doesnt know what he's got rather than the all too frequent liar or fool! how often do you see ads on CL,etc where the poster calls any replaced/changed part on a half ton a "1 ton upgraded such and such" and when you see these supposed 1 ton parts,there often 3/4 or even 1/2 ton items! I'd bet that in the last 5 years or so on CL and other sources,ive seen 3 times more ads claiming 1 ton parts,than there have been 1 ton trucks built..............
Old Jun 15, 2008 | 07:44 PM
uncle.stosh's Avatar
uncle.stosh
Yep, it's a 44.
Some 78/79 F250's also came with HP D60's. I just scored one for $100 out of one.
Old Jun 16, 2008 | 01:49 PM
Ford400Man's Avatar
Ford400Man
Would a Dodge D60 work under my Bronco? they are driver side diffs. I need to weld on c- blocks anyhow???!
Old Jun 16, 2008 | 01:55 PM
75F350's Avatar
75F350
The only dodge axles with a drivers side diff. are late model axles, and are very undesireable.
They have no locking hubs, an axle disconnect, and unit bearings.
Really not worth the effort.
Old Jun 18, 2008 | 09:39 PM
Ford400Man's Avatar
Ford400Man
So, Let me see if I got this straight:
D44HDs have a J shaped steering arm, and D60s have a straight arm, Right???
Are there any other things to look for? I am just getting into the 3/4 ton parts after years of running the 1/2 tons.
Old Jun 19, 2008 | 11:09 AM
crazyredneckanyhow's Avatar
crazyredneckanyhow
yeah 60s have a strait arm. Its easier to look at the top of the knuckle/outer C Itll have kingpins. A flat cap with 4 bolts . A 44 will be like your bronco with a balljoint
Old Jun 19, 2008 | 11:53 AM
captain p4's Avatar
captain p4
they made kingpin 44's too cheeto
STGFordCrazy04
D44HD fronts have a J shaped steering arm that curves out in front of the axle held on by 3 studs and ball joints as mentioned. D60s will have the steering arm that points straight toward the passenger side front tire held on by 4 studs. The steering arm is also a king pin cap with a grease fitting.
MrAgent007
Apr 6, 2014 07:38 PM
RAY1986F150
13
Sep 23, 2012 12:49 PM
Ricohman
Jul 19, 2011 10:16 PM
Thomasm67
Kansas Chapter
Dec 6, 2010 08:48 AM
BigF350
International Region
Jan 2, 2009 03:29 PM
