Hpop leak, need some help
Old Jun 15, 2008 | 06:11 PM
That_Guy's Avatar
That_Guy
Im leaking oil from my HPOP, seems to be coming from te drivers side where there are 2 fitting with hoses coming out of the HPOP directly under the fuel bowl. Can I just tighten up the fittings? Ive had a seal replaced twice by the dealer and it got worse everytime so now Im goin to fix it so it can be done right.
Old Jun 15, 2008 | 06:17 PM
ron's power stroke's Avatar
ron's power stroke
you sure can..they most likely didnt use the lock tight on them fittings
7.3L Ford Powerstroke High Pressure Oil Pump O-Rings
i also have an r&r link..but its too big to post..if you want it..PM me your e-mail adress....
Old Jun 15, 2008 | 06:27 PM
That_Guy's Avatar
That_Guy
Thanks Ron, PM sent
Old Jun 15, 2008 | 06:32 PM
ron's power stroke
e-mail sent ...good luck...
Old Jun 15, 2008 | 06:36 PM
That_Guy's Avatar
That_Guy
Thanks, reps sent
Old Jun 15, 2008 | 06:40 PM
ron's power stroke
thanks Chris...there is also a install write up in my mods and fixes link in my sig if your going to pull the pump out....
Old Jun 15, 2008 | 06:46 PM
That_Guy's Avatar
That_Guy
ok, ill take a look at that to.... if i take it out might just have to get a pulse...lol
