Sponsored by: Real Truck
Help, need quick torque spec....
Old Jun 14, 2008 | 10:17 PM
jinxie's Avatar
jinxie
Ive got the truck nosed in the shop and cant close the door until I get it back together....didnt think it would take as long.
I was replacing the rear brake pads and i had 1 broken wheel stud. Well I almost have the hub off to replace the stud......what is the torque of the 4 slot nut that holds the rear wheel bearing on?
Thanks!
Old Jun 14, 2008 | 10:33 PM
PowerStrokeHD's Avatar
PowerStrokeHD
According to the WSM it is 60 lb/ft (81 Nm)...
2002-WSM
From the table of contents select 05: Driveline. From there select Section 205-02E. Then select Hub under removal and installation...
Old Jun 14, 2008 | 10:40 PM
jinxie's Avatar
jinxie
Thanks for the link
Old Jun 14, 2008 | 11:52 PM
jinxie's Avatar
jinxie
I ended up torquing to 60 ft lbs and then backing it off 5 clicks......hope it works!!
