1990 F250
Old Jun 14, 2008 | 04:20 PM
Country705's Avatar
Country705
1990 F250
I am Trying to decode the white tag on the cab of my grandfathers truck can anyone tell me what all of this means.
LT 235-85R16 Tires (Obvisouly this means tire size)
16X6 K Rims (Rim Size)
3.5 Axle
Springs EA
Trans: W
Vin:1FTHF25Y4LNA47311
anyways thanks in advance for all the help just trying to get all my information straight before i start restoring the truck.
Old Jun 15, 2008 | 12:59 PM
Country705's Avatar
Country705
come on someone surley knows the answer to this
Old Jun 15, 2008 | 01:11 PM
TattooJim's Avatar
TattooJim
VIN Decoder
you might try this. Might fill in some blanks VIN Number Decoder offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Old Jun 15, 2008 | 02:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by turnerjc03
Springs EA / Trans: W / Vin:1FTHF25Y4LNA47311
Springs EA: E = Front Spring / A = Rear Spring. These codes are used to determine what the p/n's of the springs are.
Trans W = ZF 5 Speed
1FT = FoMoCo USA World Manufacturer (Complete Vehicle)
H = Class H GVWR = 9,001 to 10,000 lbs.
F25 = F250 2WD Regular Cab
Y = 300 1V
4 = Ford Internal Use Only
L = 1990
N = Norfolk VA Assembly Plant
A47311 = Numerical Sequence of Assembly
Old Jun 15, 2008 | 04:06 PM
DJdemon6696's Avatar
DJdemon6696
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company, USA
Make: Ford
Vehicle Type: Truck (Completed Vehicle)
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class G, GVWR 8,501-9,000 pounds, None
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: F-Series - F250
Chassis Type: 4x2
Body Type: Pickup - Regular Cab
Engine Type - 8th Position:
Engine: 4.9(300cid)
Cylinders: I-6
Fuel Type: Gasoline
Horse Power: TBD
Model Year - 10th Position:
Model Year: 1990
Assembly Plant - 11th Position:
Assembly Plant: Norfolk: Norfolk, Virginia
Production Sequence Number - 12th - 17th:
Sequence Number: A47311
Old Jun 15, 2008 | 04:22 PM
NumberDummy
The OP's VIN has an H as the fourth digit, not a G.
My info came straight from the: General info section of the: 1990/2002 Ford Light Truck Parts Catalog.
Myout
Feb 23, 2012 05:20 PM
HateTank
22
Mar 29, 2007 02:07 PM
rallyman
Mar 16, 2005 03:19 PM
rallyman
Mar 16, 2005 05:09 AM
flyhound
Mar 1, 2004 03:27 PM
