Heater core leak
Old Jun 14, 2008 | 02:02 PM
pk8950's Avatar
pk8950
Heater core leak
Driving my 79' last night when my daughter says there yellow fluid coming from under the dash. I assume its the heater core, can I get one of these a the locol parts store or is it going to be more difficult than that.
thanks
Paul
Old Jun 14, 2008 | 02:06 PM
F250army45d's Avatar
F250army45d
I ordered mine off AutoZone.com had it in seven days could of had it faster but didn't want to pick it up.
Old Jun 14, 2008 | 02:13 PM
daddy172005's Avatar
daddy172005
I got mine from Advance Auto. They had it in stock. Its easy to change out. Atleast it was on my 74. There was 2 nuts on the firewall to remove the whole assembly. Remove your hoses and disconnect your linkages under the dash. The assembly should slide right out.
Old Jun 14, 2008 | 02:38 PM
Tedybear's Avatar
Tedybear
Pick up some cleaner while you are at it. Pulling the heater box and opening it up for access to the heater core = good chance to clean the crap/crud/dust/leaves/gremlins out. Plus last time we made about a 5 spot in loose change that over the years falls through the duct work.
S-
Old Jun 14, 2008 | 06:25 PM
pk8950's Avatar
pk8950
That sounds good, thanks for the info.
Old Jun 14, 2008 | 07:02 PM
73f100shortbed's Avatar
73f100shortbed
I got mine through local parts place as well.
Old Jun 14, 2008 | 09:35 PM
Troy77+79's Avatar
Troy77+79
It's easy if you're truck doesn't have air. If it has factory air, it's a real PAIN.
Old Jun 14, 2008 | 09:50 PM
pk8950's Avatar
pk8950
It took about a half hour to change. It was alot better than doing a fox body mustang one for sure.
Old Jun 15, 2008 | 02:38 PM
fastfarmer's Avatar
fastfarmer
Like your truck, fox bodys are a whole diffrent job depending on with or without air.
Old Jun 15, 2008 | 06:43 PM
straightsix4x4's Avatar
straightsix4x4
yep o'riellys had one in stock, 30 bucks. I had issues with the cab insulation allowing me to reinstall tha heater box, so i ripped it out, it would just soak up the murky pond water anyway
rcraft
Mar 30, 2014 03:55 PM
4x4 Bart
44
Mar 7, 2014 12:39 PM
RA31925
Mar 5, 2013 08:28 PM
Drac
Dec 20, 2011 10:15 PM
Paul Therriault
Jan 24, 2006 07:55 PM
