Block coolant drain?
Old Jun 14, 2008 | 08:06 AM
parr4's Avatar
parr4
I can not find a block-drain on my 300cid engine. Haynes manual claims there is one on the LH rear of the block, but there isn't. How can I drain the block? Thanks for any advice on this.
Old Jun 14, 2008 | 09:29 AM
Archion's Avatar
Archion
Veteran: Marine Corps
It will be just a pipe plug more than likely, the type with a square head. When I do rebuilds I replace these with radator type pet*****.
Old Jun 14, 2008 | 01:27 PM
parr4's Avatar
parr4
I was looking for something protruding in that area, but maybe you are describing a 'flush' type plug with a square-drive indention? I'll get out my glasses and brightest light and look harder. Thanks for the response.
Old Jun 15, 2008 | 08:46 AM
63redtudor's Avatar
63redtudor
Look under the exhaust manifold, between the last 2 freeze plugs.
Look here: BB6
Edwin
Old Jun 15, 2008 | 09:37 AM
parr4's Avatar
parr4
ok, Red. I knew that sensor was there. I was going by the stupid Haynes book that claims there is a drain at the LH rear of the block.....easier to deal with than the sensor area. Thanks
