Have a Road Armor front and rear on my 2005 and an ARB on my 2000.
RA- had to fabricate braces for the front as it did not mount solidly, no braces only 4 bolts as shipped. RA rear , I had to make 1/2" spacers to keep bumper off of body. Had to make spacers to use their gas can carrier.Units are expensive and solid but not truly bolt on, once you make braces, spacers it is a good job.
ARB mounted solidly, good unit, easy bolt on.
Not doing Road Armor again ! Too much $ and too much additional work !
I've got RA front and rear on my 04; no complaints whatsoever from me in terms of unit construction; only finish. The RA powdercoat sucks; if I was going to do it over I would order the bumpers raw and coat them with Line-X or some other durable epoxy finish.
