EGT temps
Old Jun 13, 2008 | 09:27 PM
That_Guy's Avatar
That_Guy
EGT temps
My dad has a 05 6.0 dually, basiclly stock excpt for gauges. We were both wondering whats the highest safe temp?
Old Jun 13, 2008 | 09:34 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Is your probe pre-turbo or post-turbo?
Old Jun 13, 2008 | 10:10 PM
That_Guy's Avatar
That_Guy
Im assuming its pre turbo since thats the way its suposed to be done....Id have to double check with my dad in the morning
Old Jun 13, 2008 | 10:17 PM
thedaddycat's Avatar
thedaddycat
From everything I've seen you are safe under 1200*F. There are some out there who will relate stories of going much higher for short times(like drag strip runs) but for most folks the 1200 mark is safe.
Old Jun 13, 2008 | 11:24 PM
That_Guy's Avatar
That_Guy
Thats what I thought, he hits 1200 when towing hills somtimes. Thanks for the info
Old Jun 13, 2008 | 11:35 PM
adambomb's Avatar
adambomb
from what i have learned from this site, these trucks can run @ 1250 deg all day long w/o a problem. anything higher should only be for quick burst like >5 seconds.
Old Jun 14, 2008 | 03:52 AM
broncobran68's Avatar
broncobran68
i have an edge evolution with egt probe mounted pre turbo and with it set at 100hp i can hit 1500 but stock i can barely hit 1000. the alarm on it is set at 1250 by edge so that is usually when i back out of it. if anyone else could chime in on this i would be interested to know some more.
Old Jun 15, 2008 | 02:41 AM
That_Guy's Avatar
That_Guy
How much would a 4in turbo back exaust lower his EGT's? I didnt have gauges when I did mine so I dont even know how much min was lowered...
Old Jun 16, 2008 | 12:00 PM
Dustball8504's Avatar
Dustball8504
I've seen as high as 1600 on my truck but that was with a very hot tune down a dragstrip. Now with my new tune in the truck which put the numbers down in my sig and the addition of a banks intercooler I can hardly get it over 1450 and normal driving is usually around 800-900. Even towing hills with this tune is still in the 1200 range.
