410 Timing question
Old Jun 13, 2008 | 07:40 PM
F250army45d's Avatar
F250army45d
410 Timing question
I have a 410 out of a 66 67 mercury wht should the timing be set to? It hs long tube headers to my knowledge every thing else is factory. My toughts would be 8 to 12% BTDC
Old Jun 13, 2008 | 08:37 PM
Bear 45/70's Avatar
Bear 45/70
That should be pretty good. A better way would be to set max mechanical advance to 36° to 38° and then check initial and us that number as the max number is more important than the initial.
Old Jun 13, 2008 | 10:24 PM
montana_highboy's Avatar
montana_highboy
Pull the breaker plate on your distributor and see what advance slot you're using, 10L 13L 15L etc. (double that) and adjust your initial advance accordingly to achieve 36 to 38 degrees total advance.
Y2K1TON
1978 - 1996 Big Bronco
Feb 14, 2015 09:39 AM
KC8QVO
Jul 20, 2010 05:46 PM
robertbourque
21
Apr 21, 2007 04:48 AM
sunney
Engine Swaps
13
May 18, 2005 02:53 PM
bond10
Nov 10, 2003 05:45 PM
