rpms staying up
Old Jun 13, 2008 | 11:46 AM
colorsink's Avatar
colorsink
rpms staying up
hi i have a 95 f150 5.0 with a 5spd when ever i go to shift gears and the rpms are between 2 and 3 thousand rpms and i push in the clutch the rpms just stay right up at the same point like i still have my foot on the gas peddle. i have cleaned the iac and the throttle body what else can be causing this problem thanx
Old Jun 13, 2008 | 12:55 PM
quicklook2's Avatar
quicklook2
pedal or throttle cable binding.
Old Jun 13, 2008 | 04:27 PM
85e150's Avatar
85e150
Check the usual stuff as indicated--linkage, kinks, pedal, etc. Now see if you can look inside the cable housing. We had a truck at work where the cable started to fray inside the housing--stick city.
Good luck.
