Sponsored by: Innova
head unit wires
Old Apr 15, 2002 | 08:24 PM
78bronco's Avatar
78bronco
head unit wires
there are two conectors on the radio with cassette and digital display, one grey and one black, all have multi colored wires, where do they go?
Old Apr 15, 2002 | 09:01 PM
CobraXP's Avatar
CobraXP
head unit wires
This should be what you are looking for:
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=3426&.jpg
For the gray plug (from left to right in the pic):
green - memory feed
black - vehicle chassis ground
yellow/black - radio power feed
light blue/red - panel illumination
orange/black - radio display
black/light green - radio ground
For the black plug:
orange/light green - left front speaker +
light blue/white - left front speaker -
pink/light green - left rear speaker +
tan/yellow - left rear speaker -
white/light green - right front speaker +
dark green/orange - right front speaker -
orange/red - right rear speaker +
black/white - right rear speaker -
Your wires may not be the same colors, but they should be in the same order on the plugs. Check the power and ground with a test light to make sure, then check each speaker set to double check also...
Hope this is what you were looking for...
Old Apr 16, 2002 | 01:05 PM
78bronco's Avatar
78bronco
head unit wires
so then the entire grey plug has either + or ground
Old Apr 23, 2002 | 12:18 AM
IlllMikeIlll's Avatar
IlllMikeIlll
head unit wires
whats the other wire for... and also i have a clip i found at the junkyard... and the colors arent exactly the same but theres wires in most of the slots except for the second to the last... on the grey connector... that ones all the way at the last slot... im gunna try moving it and see what happens... but i have another wire on another smaller clip..whats this?
Old Apr 23, 2002 | 11:50 PM
wafflerr's Avatar
wafflerr
Post head unit wires
