General Automotive Discussion
97 ranger timing
Old Jun 12, 2008 | 05:50 PM
andjess's Avatar
andjess
Question 97 ranger timing
im trying to find out what the timing marks are on a 97 ford rander with 2.3 engine. thanks.
Old Jun 12, 2008 | 08:07 PM
jimdandy's Avatar
jimdandy
Camshaft:
There will be a diamond and a triangle on the gear teeth. Use the triangle for timing. On the rear timing cover there will be three white marks about 5:00. The triangle will point to the center mark for proper timing.
Auxilary shaft:
The auxilary shaft will also have the diamond/triangle. Use the diamond to align this gear. It will align with another diamond on the rear cover. It will be straight up.
Crankshaft:
The crankshaft will be at top dead center when the keyway is straight up. There is also a dot on one of the teeth of the crank gear. This dot will point to the leading edge of a notch in the crank seal cover about the 1:00 position. jd
