Sponsored by: Innova
Alternator Noise
Old Apr 29, 2002 | 08:53 PM
Jigsaw's Avatar
Jigsaw
Alternator Noise
OK Guys, Here is a low-tech question. I put a stock AM radio into my '66 F100. It never had a radio before. I get alot of "whine" what increases with engine speed. How and where do I need to install some sort of capacitor to eliminate the radio interferance?
Jerry (OldTrux) Biskup
Itasca, IL
http://hometown.aol.com/oldtrux/jigsaw.html
<----- FTE #0079
Old Apr 29, 2002 | 09:02 PM
spoon059's Avatar
spoon059
Alternator Noise
If you take the radio out and find the ground wire (usually black), you may need to replace that. Noise is almost always due to a grounding problem. If you can splice a slightly bigger wire into the ground wire and find a bolt or something to hook it up to. That should solve the problem.
Old Apr 30, 2002 | 07:55 AM
John8172's Avatar
John8172
Alternator Noise
