Are there certain brands that should be avoided? I found on Ebay a person selling 3 filters for $26 which seems like a real bargain, but if someone knows something I don't I'd hate to waste my money on junk filters.
The ones that are on that link are the drop-in style. You gotta keep your lid from before. I can't recall which brand recently made the change, but somebody posted on here that their particular brand of fuel filter started using the lid that is fixed to the filter. Either will work.....as long as you save the lid for future use!
I'm aware of the lid vs. no lid thing, luckily right now I have a lid-less filter so if I end up getting one with a built-in lid I can keep the one I have. I do wish it had the recess in it for a ratchet, but the one time I took it off it came loose without much problem.
I am not familiar with the deal on the Drop in fuel filters with no cap, don't have have to modify your exisiting cap? I am about to order me some Racor's off of Geno's just like to know what I have to do.
Depends on what you have. From what i read here about the "drop in", you are unable to get the lids off to be reuse on a lidless filter. Unless you have the stock lid laying around on a shelf somewhere.
Dan linked to some good photos there. The racor filters from geno's are the ones you unscrew your cap, replace the filter and o-rings, and screw the cap back on.
The other kind you unscrew the filter, throw the cap and filter in the trash, put a new filter and cap back in. The filter is glued to the lid so the whole thing is garbage when you're done with it.
i have the stock lid with a drop in filter..i only hand tight the thing so i can take it off by hand if i need to take it off side the road....8 filters later and i have never had a cover leak..i have heard that some of them filter's with a built in cap can be a pain in the azz to keep from leaking.......
