Sponsored by: Innova
Size DD
Old May 1, 2002 | 07:44 PM
rellik74's Avatar
rellik74
Size DD
I have a 98 Ranger with the double din mount, It craped out and have had no luck finding a double din replacement for it. I live in a small town and will need to order one on line as here if walmart don't have it you cant get IT!
Thanks Phil
Old May 1, 2002 | 08:55 PM
CobraXP's Avatar
CobraXP
Size DD
Are you looking for another factory head unit, or an upgrade like Alpine or something?
Old May 2, 2002 | 05:55 PM
rellik74's Avatar
rellik74
Size DD
I would like to upgrade but do not find any size DD, Unless someone has a factory unit laying around
Old May 3, 2002 | 01:25 AM
DanB98TJ's Avatar
DanB98TJ
Size DD
Check with Crutchfield (http://www.crutchfield.com) for a double-DIN unit. If anyone has one available, they will.:-)
You can also purchase an installation "kit" that will allow you to use a standard DIN stereo. The ones I've seen normally run around $15-20, and look good...not like some Mickey Mouse install.
Old May 3, 2002 | 07:08 AM
CobraXP's Avatar
CobraXP
Size DD
I know Alpine, Kenwood, and Pioneer still make the double dins. I run an Alpine and love it. I run an Alpine double din in my X.
If you are just wanting a factory head unit, I do have one, would just have to know if your wiring harness is the same for the radio I have.
Let me know...
Old May 3, 2002 | 05:49 PM
rellik74's Avatar
rellik74
Size DD
Well first thanks for the help, I found an adapter setup for double din to reg din and it gives you a shelf under your radio and I think I will mount my CB in the slot for a built in setup.
Thanks Phil
Old May 8, 2002 | 02:22 PM
jack 9520's Avatar
jack 9520
Size DD
Mark Lighten
Jun 27, 2012 07:47 PM
d5332
Dec 24, 2010 02:27 PM
lilpro
Mar 10, 2010 11:38 PM
carolinabosox
Jun 25, 2007 04:13 AM
caadoptees
Jun 11, 2007 11:39 AM
