2000 Ranger ECM not responding
Old Jun 12, 2008 | 08:31 AM
BadHabitinVA's Avatar
BadHabitinVA
My buddy's son has a 2000 Ranger with the 3.0L.
He called me and asked for advise on repairing his truck.
Seems he had it throw a code last year and had it scanned. The scan said it was an O2 sensor. He did not repair it and the check engine light eventually burnt out. Now the truck has developed a rough idle, low power, and general drivabilty problems.
I hooked my scanner to the port and the ECM will not communicate. I unplugged it and scanned another Ford car sitting in the shop and it cycled through just fine. I then turned on the lights and unhooked the battery for two hours. I tried to scan again, and again it wouldn't read.
Suggestions?
Old Jun 12, 2008 | 10:15 AM
Rags's Avatar
Rags
Check the fuse for the cigarette lighter. If it is blown your scan tool will not communicate.
I had this happen on a 2000 exploder.
Old Jun 12, 2008 | 11:57 AM
BadHabitinVA
Wow...I'll do it tonight. Thanks!!
Old Jun 13, 2008 | 08:35 AM
pawpaw's Avatar
pawpaw
Yup, Rags is right on, the diagnostic connector port 12 volt source for the scantool is through the cigar lighter fuse!!!!
Post ALL the code numbers you pull & the sequence in which they came, ie KOEO & KOER.
