302?
Old Jun 11, 2008 | 09:43 PM
MER's Avatar
MER
302?
How much hp can a well built 302 with the right heads and cam make?
I tried to do a search and cant get through, I know the ? has been gone over and over! But THANKS IN ADVANCE!
Old Jun 11, 2008 | 10:44 PM
Conanski's Avatar
Conanski
As much as you have money for. I know that's not the answer you wanted but it depends what you start with and how much you spend to build it up. A factory iron block will only support about 450hp before keeping the head gaskets sealed becomes an issue. And making that kind of power reliably for thousands of miles is a lot more expensive than making it for 1 trip down the track. You could strap some big AFR heads on a 5.0, plug in a cam that makes power out to 8000rpm and get well over 400hp, but it's won't work too well in a big ole truck, so what's the point.
Old Jun 11, 2008 | 10:45 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Around 300-320hp for a nice truck engine. In a hot rod 400+ is possible. How you're going to use it makes a big difference in how much money money you'd need to spend (and where).
Old Jun 11, 2008 | 10:56 PM
85e150's Avatar
85e150
Some of it was gone over here:
https://www.ford-trucks.com/forums/716787-302.html
Including a link to another thread about a 530 hp 331 in Hot Rod....
Old Jun 11, 2008 | 11:16 PM
12secondstang's Avatar
12secondstang
My mustang has a well built balanced stock bottom with forged piston 306 and AFR heads N/A. I put est. hp at 390 at the wheels. About 425 at the motor. Shifting at 6900 with a 5 speed. These 5.0.s can take some serious power. Get a main support if you do build up the motor. All said and done I put about $6000 into the motor but it has lasted over 6 years of hard 11 second passes and weekend street use.
