'95 F250 A/C Problem
Old Jun 11, 2008 | 03:54 PM
iambraeden's Avatar
iambraeden
Red face '95 F250 A/C Problem
I just inherited this F-250 from my grandfather this past week and all was running well due to his excellent care of his vehicles. While putting in my stereo I had to run the cables from the back of the head unit and the only way I could get the cables to run was to put a clothes hanger through first (not a smart idea i know) and since I did this my A/C has been messed up. Every setting (Max A/C, Normal A/C, Vent...) makes the air come through the defrost vents only. The air is still very cold so I don't think it simply went out, I know I screwed it up :\. Anybody know anything I can do to fix this?
P.S. This is my first experience with working on vehicles so please use simplified terms and a bit of details please. Thank you for all the help. And also, sorry about reposting this, I did search for help on the forums first but I didn't understand most of the terms used or the posts were very old.
Old Jun 11, 2008 | 04:06 PM
quicklook2's Avatar
quicklook2
you messed up the vacuum line.
Old Jun 11, 2008 | 04:25 PM
Virto's Avatar
Virto
Sounds like you cracked or disconnected the vacuum line that operates the blend door.
Do a quick search for "blend door" and you'll find a wealth of info on fixes.
Old Jun 11, 2008 | 04:45 PM
danr1's Avatar
danr1
And don't be poke'n around with a hanger under the dash no more!
Old Jun 11, 2008 | 07:24 PM
iambraeden's Avatar
iambraeden
yea it was kinda retarded to be messin around in there without experience, thought I was being careful but I guess not careful enough
