How Difficult...
Old Jun 12, 2008 | 03:14 PM
Littlejon's Avatar
Littlejon
Yeah, it has the little screen in there, but the in-line filter as well. Screen has been cleaned up pretty good and is in good shape.
I need to see if I can get some more of the crud off the front of the carb to see if I can get the model number. If not, is there anywhere else that an identifying number can be found? It has a blue "tag" atached to it, but I don't know if the number on it would reference anything that could identify the model I have.
I am in new territory here as I have always had fuel injected imports to work on. Last American made vehicle I had was a '72 International Scout. Pulled the carb off of it and replaced it, but that was probably 20 years ago at least.
Old Jun 13, 2008 | 12:32 AM
Sycostang67's Avatar
Sycostang67
I am pretty sure holley makes a universal carb rebuild kit that would work on your carb. When you go to the parts store they usually have 2 different kits, the one for double pumper carbs and the one for the regular carbs. The kits come with gaskets for several different carbs. You just use the gaskets that match the ones you remove. I used one of those kits to rebuild a Ford/holley carb for a friend with an old ranchero that had a 460. His carb looked just like yours but without the bowl vent on the back.
Old Jun 13, 2008 | 12:44 PM
Littlejon's Avatar
Littlejon
Cool! I may just give that a try. Like I said, tank issues are first and foremost, but I know the carb needs to be rebuilt.
Thanks for all the help!
Old Jun 13, 2008 | 06:05 PM
SuperSnake's Avatar
SuperSnake
I used paint thinner in my tank to clean it out. Soaked a couple of hours and was good as new and I put a new fuel pump on the sending unit and a float.
Old Jun 14, 2008 | 02:15 AM
Piffery1's Avatar
Piffery1
After looking at your pictures again, it looks like an 1850 Holley.
Old Jun 16, 2008 | 12:19 PM
Littlejon's Avatar
Littlejon
Interesting. Thanks for the info!
Is there anything in particular I need to know about that model carb? Are rebuild kits pretty common or will I need to dig to find someone who has one?
Well, I managed to get the tank out and it had some stuff in it, but not nearly as bad as I expected. Very minor rust in the bottom of the tank, but not much at all. There is something that sounds like gravel rattling around and it won't come out, even after hosing it down real good, so I am letting it air out and dry completely in the 90+ degree sun today and will run a small hose on the end of the shop vac in there to get it out. I am probably going to drop a chain in (new, of course) and rattle it around to knock any other loose stuff off before I do, but I figure the shop vac will suck up any and all loose particles I have left over.
Do auto parts stores carry any kind of coating or sealer to put in tanks like this or is it special order stuff? Any thoughts on what to get or avaoid?
Sending unit looks to be in good shape, but I am going to replace it anyway. Aside from that, everything else looks good. There is some sort of pressure release valve or something with a vacuum hose attached that sits in another hole in the top of the tank. Can't tell if this thing is working right or not and I don't know where the hard line goes that the vacuum hose attaches to.
Any ideas on that thing? I can put pics up tonight if need be.
Old Jul 12, 2008 | 07:59 PM
Littlejon's Avatar
Littlejon
FINALLY got the old girl back on the road!
I managed to get the tank cleaned out pretty good. I got almost all of the rust out, just some very minor surface rust I couldn't get to in one spot. I think there must have been a lot of gunk in there from where it had sat for so long, because it kept gunking up the filter.
Anyway, got the new sending unit back in, replaced a couple of rubber lines and put it all back together. Put is about 5 gallons of fresh gas and.....
she wouldn't fire! I was ticked. So, I pulled some lines and blew them out good, still nothing. Pulled the line from the new fuels pump (MAYBE 2 months old) and had my son turn it over and she wasn't pumping. Soooo, put in a new pump and fired her up yesterday for the first time in over a month.
She actually runs pretty good right now and the problem I had before with gas draining out of the lines and back to the tank seems to have stopped as well, since the filter is full of fuel.
Now, I am looking at replacing that old carb next. Still a lot of stuff to do to get her where I want her, but with limited funds and even more limits on time, it has been slow.
Wanted to say thanks for all of the help and I am sure I will be picking your brains some more before it's all said and done!
fp_5
Oct 24, 2021 12:07 AM
khaitan
28
Dec 3, 2016 08:38 PM
Dudes BBQ
Dec 17, 2014 07:26 PM
skapford
13
Aug 3, 2013 11:32 PM
VintageBlueOval
Oct 14, 2009 06:49 AM
