Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Restoring an 18v battery
Old Jun 10, 2008 | 09:33 PM
dffay's Avatar
dffay
My Bosch 18 volt NiCad tool batteries don't seem to hold the charge much any more. I don't abuse them and they aren't that old.
Anyone know how to restore them to take and hold the charge? They charger is doing its work. But after a few days on the shelf they run the drill/recip saw/planer etc for just a short time.
Old Jun 10, 2008 | 09:37 PM
jwtimme's Avatar
jwtimme
some places will rebuild you batteries for about 1/2 of what you can uy new ones for. We have an interstae batterie store that rebuilds my dewalts. but after they go down hill they are normally done with.
Old Jun 11, 2008 | 12:14 AM
ford2go's Avatar
ford2go
NiCads can have a 'memory' problem if you don't run them all the way down.
They 'remember' that they recharged at an early point, and they start to crap out at about that point.
The NiCad people say it's not true, and then they go through an explanation of something that sounds like a memory problem.
I have heard that this can be corrected by completely discharging them, and then recharging. You will need a resistor of fairly low value connected across the terminals -- don't just short them out. Leave it for a day or two, and then recharge them. Hopefully it will help.
After that run them a long way down when you use them. If this isn't convenient, use the resistor trick. You may have to do that anyway because some devices will cut out at a certain point, and you won't get a good discharge.
Hope it works for you,
ford2go
Old Jun 12, 2008 | 03:21 PM
dffay's Avatar
dffay
18v battery problem
I'll give that a try. The NiCad people have written that running the battery all the way down can switch the voltage direction. I can't image there not being some type of diode in there somewhere but then who am I?
I'll try the resistor thing. And, I googled the issue and some guys are arcing them with a little higher voltage to solve the problem. Its said to be a dendrite issue. I'll need a bunch more research on that one before I hook it to my dc welder. Sounds like a Darwin Award finalist stunt.
Thanks for the response.
Old Jun 12, 2008 | 05:15 PM
Lead Head's Avatar
Lead Head
Don't discharge a NiCD battery pack all the way to nothing with a resistor, if one cell drops to a lower voltage then the other, it cause reverse current flow.
Your best bet would be to give the battery a bunch of hard working, fresh off the charger and use it until the the power tool its powering stops working.
It would be perfectly safe however to take the battery pack apart, and discharge and recharge each individual cell however
Old Jun 12, 2008 | 07:03 PM
dffay's Avatar
dffay
18v battery
It actually made more sense to me to exercise it more but I have wondered how the guys that "rebuild" them do it.
I'll just work them more and see what that brings.
Old Jun 12, 2008 | 11:43 PM
ford2go's Avatar
ford2go
Had never heard of that reverse flow stuff before, but the explanantion seems plausible.
Most of my experience has been with singls cell NiCads.
ford2go
ScaldedDog
13
Mar 15, 2014 06:02 PM
Ratherbeefishin
Dec 27, 2013 11:24 AM
pym
Jan 4, 2012 06:46 PM
bratman2
Garage & Workshop
Dec 28, 2006 06:08 PM
weldman
Apr 28, 2001 12:11 AM
