I got an explorer
Old Jun 10, 2008 | 07:39 PM
paintslinga2010's Avatar
paintslinga2010
I got an explorer
I normally drive an 89 f250. Gas sucks so my parents bought a focus. So the explorer is now mine. Ill never sell the f250 but when im low on cash ill drive the explorer.
First thing: The drivers side door doesnt unlock when you hit the unlock button, and the rear main door doesnt open at as of a couple weeks ago.
What needs to be done or bought to fix this? parts, links, anything helps.
Its a four door with a 4.0 v6. Should i just leave it stock? I have problems not mesing with stuff to make it have more power. So convince me to leave it stock or tell me something cool i can do.
For now i want to figure out the door situation, I have never dealt with anything with automatic locks/windows.
Thanks in advance.
Hope this section is as great as the 87-96 sct.
Old Jun 10, 2008 | 08:54 PM
elmo8641's Avatar
elmo8641
to test the door locks you need to remove the door panel. back prope the door lock actuator. hit the lock button and see if you have 12v to lock and -12 to unlock. if you do, then the actuator is bad. if you don't then you have a wiring problem. if you got this exploder to save on gas then you should just leave it alone. put your money in the truck.
