Strange uses for common things thread!!!
Old Jun 11, 2008 | 03:22 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer: If silicone gets on clearcoat paint...it will strip the clearcoat off. Pay close attention to the wax used on clearcoat paint. If it contains silicone...do not use it. Same thing for spray can dusters used on furniture. These contain silicone, and you don't wanna spray that crap on antique furniture with oiled or French Polished (shellaced) wood finishes.
Good advice.
So when using the silicone lubricant on the weatherstriping, and rubber parts, take care not to get it on the paint if it's clearcoat.
Also another trick".
Jeweler's Rouge with a light buffing wheel will clean up oxidized plastic lenses like tailights, and marker lamps assymblies and front turn signals.
Jeweler's rouge will also remove water spots and very light blemishes on windows too.
Old Jun 13, 2008 | 04:55 PM
FESTER1st's Avatar
FESTER1st
WD-40: rather than starting fluid will kick off a diesel engine and is much less hazardous to you and the engine.
Plumbing our oilpan drains to accept a 1/2" hose can really help in many ways in aiding us for those mods that make oil changes a little tricky or cumbersome. Cut the hose to you desired length and plug with whatever you've got lying around that will be easy to remove.
Old Jun 14, 2008 | 04:36 PM
fordtruck1775's Avatar
fordtruck1775
when putting a oil pump in pack it full of vasoline (petrolium Jelly), this will keep it lubed until it gets started and oil is pumping through.
Old Jun 15, 2008 | 07:15 AM
Lone Wolf #2's Avatar
Lone Wolf #2
Aluminum polish also works to remove haze from headlights and tailights. Follow up with plastic polish for good as new.
Old Jun 15, 2008 | 08:08 PM
Dr. Dirt's Avatar
Dr. Dirt
JBrad and Lone Wolf, do you wipe it on the light and the haze will come off?
Old Jun 15, 2008 | 08:13 PM
Dr. Dirt's Avatar
Dr. Dirt
or do you have to take the light apart?
Old Jun 19, 2008 | 11:03 AM
Lone Wolf #2
Use it just like a polish, keep rubbing until the haze goes away (doesn't take to long.) The aluminum polish works as a first cut to get the worst of the haze and the plastic polish finishes it off. Keep in mind, this is only for haze, deep scratches and rock chips will require sanding or replacement.
Brnfree
Jun 10, 2013 09:38 AM
droldsmorland
Jun 3, 2013 06:16 PM
montana_highboy
Sep 4, 2012 02:40 AM
Prairie Lariat
Feb 1, 2007 03:28 PM
securitydog1
Paint & Bodywork
Nov 17, 2005 08:44 PM
